English
Error: sdeservice.exe unable to locate DLL
Error Message
Installing ArcSDE returns this error:
The dynamic link library sde80.dll could not be found in the specified path...
Cause
ArcSDE for Coverages client not installed.
If only the ArcSDE for Coverages Server is installed on a machine that does not have ArcInfo, certain DLLs will not be installed. As a result, the error is returned during the installation. The installation may finish; however, the service will not be installed nor will ArcSDE for Coverages be available.
Solution or Workaround
  • Install both Server and Client on a machine that does not have ArcInfo installed. All the necessary DLLs will be installed and the service should start.
  • Install ArcSDE for Coverages Server on a machine that has ArcInfo installed. All necessary DLLs will be installed or will be used from the existing %ARCHOME%/bin directory for a successful installation to occur.
    Note: ArcSDE for Coverages is a stand alone application (Server and Client), this means it can be installed on a machine that does or does not have ArcInfo already installed.
