English
Error: Connect Failed to connect to database. Login failed for user 'test'
Error Message
When trying to view in OLE DB data in ArcMap or ArcCatalog, one of the following error messages is returned:
"Connect
Login failed for user 'test'."
Or:
"Connect
The user and/or password is invalid.
Cause
The password was not saved with the connection string and was not passed to the DBMS.
Solution or Workaround
When setting up the OLE DB connection, select to save the password in the Connection tab of the Data Link Properties dialog box.
Check the "Allow Saving Password" box.
[O-Image] Data Link Properties dialogue box
