English
Error: Symbol xxxx was referenced ... symbol was not found
Error Message
Starting SDE with the command sdemon -o start produces this error:
rtld: 0712-001 Symbol xxxx was referenced from module xxxx/sdeexe302/lib/libsdesrvr.so(), but a runtime definition of the symbol was not found.
Cause
The Informix ClientSDK (Client Software Development Kit) was not installed on the Informix server.
Solution or Workaround
  • Use the Informix command check_version csdk to display the version currently installed.
  • Install the ClientSDK. Be sure to use the version that is certified for use with SDE.
Related Information
