HOW TO
Increase memory parameters for Java VM
Summary
ESRI recommends increasing the Java VM memory parameters to support Manager and the Java Viewers.
Procedure
  1. Click Start > Settings > Control Panel > Java Plug-in.
  2. On the Advanced tab, set the required memory parameters in the 'Java Run Time Parameters' field.
    This is an example for a machine running 256 MB of Ram.
    [O-Image] Java VM run time Parameters
  3. Click the Basic tab, check 'Enable Java Plug-in' and click Apply.
Article ID:000002030
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
