English
How To: Check the Microsoft VM version
Summary
To run ArcIMS, it is necessary to install Microsoft VM 3186 or higher. The version of Microsoft VM can be checked by using the Windows Command Prompt.
Procedure
  1. Open the Windows Command Prompt
  2. At the C:\ prompt, type 'jview'
    Code:
    C:\>jview
    The version of Microsoft VM is found at the end of the first line returned by jview. In this example, the version is 3309.
    [O-Image] Determining Microsoft VM version
