PROBLEM
In HTML viewers, the page appears to load, but instead of seeing the map, a red X appears.
The Map Service used in the HTML viewer has the Server Output URL Location pointing to a path that is not resolvable from the client. The red X in the browser window is an indication that the path to the image is incorrect.
Get help from ArcGIS experts
Download the Esri Support App
