English
How To: Save ArcMap VBA code to separate files on disk
Summary
This article shows how to save code in a VBA project to separate files.
Procedure
  1. Start ArcMap.
  2. Create a new UIButtonControl.
    How To: Create a new UIButtonControl
Note: For more information on creating a UIControl, see the ArcGIS Desktop Help topic "Creating custom commands with VBA and UI Controls".
  1. Right-click the UIButtonControl and select View Source.
  2. Copy this code into the UIButtonControl's click event.
Code:
Dim myVBAProject As VBProject
Dim vbComp As VBComponent
Dim savePath As String
'Path to save exported files
savePath = "D:\MyVBAFiles\"
'Get the VBA project from the document and
'loop through all the components
'in the VBA project
Set myVBProject = Application.Document.VBProject
For Each vbComp In myVBAProject.VBComponents
    Select Case vbComp.Type
    Case vbext_ct_StdModule
        vbComp.Export savePath & vbComp.Name & ".bas"
    Case vbext_ct_Document, vbext_ct_ClassModule
        vbComp.Export savePath & vbComp.Name & ".cls"
    Case vbext_ct_MSForm
        vbComp.Export savePath & vbComp.Name & ".frm"
    Case Else
    End Select
