English
Problem: Layout is clipped when printed
A layout has all map elements inside the blue margin line, but when printed the output is clipped.
Cause
Layout margins are set smaller than the printer's margins.
Solution or Workaround
  1. Set the laymout margins equal to or larger than the printer's margins.
    Summary:
    Steps to set layout margins equal to the printer's margins.
    Procedure:
    Windows:
    1. Select Layout -> Page Setup menu.
    2. Set Page Size to 'Same As Printer'.
    3. Enable the 'Use Printer Border' check box.
    4. Say 'OK' to Page Setup dialog.
    UNIX:
    2. Disable the 'Use Printer Border' check box.
    3. Enter the correct margin settings for the intended printer. Landscape layouts will be rotated counter-clockwise when printed. This means the right margin in ArcView will be the top margin when printed.
  2. Confirm all map elements are inside the blue margin line.
Related Information
