ERROR
(ESRI) Vendor daemon cannot talk to lmgrd (Cannot connect to license server
(-15,11:10060) WinSock error code). Vendor daemon died with status 241.
Since this is an unknown status, lmgrd will attempt to re-start the vendor daemon. Restarted ESRI.
(this message is repeated several times.)
The IP address is incorrect or irresolvable.
Code: c:\> hostname server1In this example, the hostname is 'server1'. If the hostname command returns anything other than the machine's hostname, the TCP/IP may need to be installed or reinstalled. Contact a Network Administrator for assistance.
Code: c:\> ipconfig Windows NT IP Configuration Ethernet adapter El90x1: IP Address . . . . . . . : 198.102.62.22 Subnet Mask. . . . . . . : 255.255.255.0 Default Gateway. . . . . : 198.102.62.25Look at the 'IP Address' line for the current IP address of the computer.
Code: c:\> ping server1 Pinging server1 [198.102.62.22] with 32 bytes of data: Reply from 198.102.62.22: bytes=32 time<10ms TTL=128 Reply from 198.102.62.22: bytes=32 time<10ms TTL=128 Reply from 198.102.62.22: bytes=32 time<10ms TTL=128 Reply from 198.102.62.22: bytes=32 time<10ms TTL=128If the IP address returned by step 2 matches the IP Address returned by the ping command, the local TCP/IP name resolution is set up and functioning properly.
Code: c:\> ipconfig c:\> ping workstation1 c:\> ping server1Run these commands while on the license server:
Code: c:\> ipconfig c:\> ping server1 c:\> ping workstation1The IP address for the workstation should be identical when ping is performed on the workstation and the server. This is also true for the server. If a command returns a different IP address for a particular machine, TCP/IP is not functioning properly. Contact a System Administrator.
Get help from ArcGIS experts
Download the Esri Support App
