English
Error: A(n) Layout object does not recognize request GetThemes
Error Message
Title: Error in Legends.Show at 1199
Stop: A(n) Layout object does not recognize request GetThemes
Cause
The Custom Legend tool cannot distinguish between a view and a layout if they share the same name.
Solution or Workaround
Assign each document in the project a unique name.
Summary:
You can change document names using the Properties dialog box.
Procedure:
  • To rename a View document:
    1. Click View > Properties
    2. Type a new name in the Name field.
    3. Click OK
  • To rename a Table document:
    1. Click Table > Properties
    2. Type a new name in the Title field.
    3. Click OK
  • To rename a Chart document:
    1. Click Chart> Properties
    3. Click OK
  • To rename a Layout document:
    1. Click Layout > Properties
    3. Click OK
  • To rename a Script document:
    1. Click Script > Properties
    2. Enter a new name in the Name field.
    3. Click OK
