HOW TO
These scripts determine the bearing angle (or azimuth) of lines in a polyline theme.
angle = arcsine(opp/hyp) angle = arccosecant(hyp/opp) angle = arccosine(adj/hyp) angle = arcsecant(hyp/adj) angle = arctangent(opp/adj) angle = arccotangent(adj/opp)Side Definitions
(hyp) Hypotenuse - side opposite the right angle (opp) Opposite - side opposite the angle of interest (adj) Adjacent - remaining side
The following scripts create a copy of the original Polyline theme with an additional field containing the bearing value. The scripts use the necessary constant to calculate due north as 0 degrees, due east as 90 degrees, due south as 180 degrees, and due west as 270 degrees. To use the scripts:
1. Copy the Create Output, Bearing, and Explode scripts into separate Script Editors.
2. Assign each Script Editor document the respective name (i.e. 'Bearing'). Change document names using the Properties dialog box.
To rename a View document:
ArcView cannot edit Delimited Text tables. You must convert Delimited Text tables to the dBase or INFO format. See Related Information below.
Field Calculator
Code: '--- Create output script v = av.getactivedoc t = v.getactivethemes.get(0) ft = t.getftab gl = v.getgraphics def = av.GetProject.MakeFileName("theme", "shp") def = FileDialog.Put(def, "*.shp", "Output Theme") if (def = nil) then return nil end idfield = msgbox.listasstring(ft.getfields, "The field must contain unique values", "Select Join Field") if (idfield = nil) then return nil end tbl = FTab.MakeNew(def, polyline) fld = idfield.clone anglefld = Field.Make("bearing", #FIELD_DECIMAL, 8, 4) fld.SetVisible( TRUE ) tbl.AddFields({fld, anglefld}) theTheme = FTheme.Make(tbl) countlist = {} if (ft.getselection.count = 0) then ft.getselection.setall end for each rec in ft.getselection id = ft.returnvalue(idfield, rec) pl = ft.returnvalue(ft.findfield("shape"),rec) plist = pl.asmultipoint.aslist for each i in 0..(plist.count - 2) tbl.addrecord l = av.run("explode", {plist, i}) thebearing = av.run("bearing", {plist, i}) gs = graphicshape.make(l) tbl.setvalue(tbl.findfield("shape"), countlist.count, l) tbl.setvalue(fld, countlist.count, id) tbl.setvalue(tbl.findfield("bearing"), countlist.count, thebearing) countlist.add("added") end end v.addtheme(thetheme) thetheme.stopediting(true) tbl.seteditable(false) v.invalidate '--- End of script
Code: '--- Bearing script plist = self.get(0) i = self.get(1) p1 = plist.get(i) p2 = plist.get(i+1) theX1 = p1.GetX theY1 = p1.Gety theX2 = p2.GetX theY2 = p2.GetY theH = theX2 - theX1 '--- where theH is the horizontal difference, or delta x theV = theY2 - theY1 '--- where theV is the vertical difference, or delta y theLength = ((theH * theH) + (theV * theV)).SQRT theAngle = (theV/theLength).Abs.Acos.AsDegrees if ((theH = 0) and (theV > 0 )) then constant = 0 theBearing = constant - theAngle end if ((theH > 0 ) and (theV > 0)) then constant = 0 theBearing = theAngle + constant end '--- 1st quadrant if ((theH < 0) and (theV >= 0)) then '--- 2nd quadrant constant = 360 theBearing = constant - theAngle.Abs end if ((theH <= 0) and (theV <= 0)) then '--- 3rd quadrant constant = 180 theBearing = theAngle.Abs + constant end if ((theH >= 0) and (theV <= 0)) then constant = 180 '--- 4th quadrantt theBearing = constant - theAngle.abs end return thebearing '--- End of script
Code: '--- Explode script plist = self.get(0) i = self.get(1) p1 = plist.get(i) p2 = plist.get(i+1) l = polyline.make({{p1, p2}}) return l '--- End of scriptPolylines that have more than one segment are exploded into the new shapefile with one record per line segment. You can use the unique ID field to join attribute information of the original shapefile to the new shapefile.
Get help from ArcGIS experts
Download the Esri Support App
