PROBLEM
Status bar missing total length measurement when using Measure tool.
When using the Measure tool, the Status bar shows only the segment length, the total length is missing.
Cause
The default standard number format has been changed, perhaps by a script or an extension.
Solution or Workaround
Use Avenue to set the number format back to the default:
1. Open a new Script window and type the following:
Code:
Number.setdefformat("")
2. Compile and run the script
See the online help for details on the "SetDefFormat" request.
Alternatively, you may import the project into a new one:
1. Turn off all unneeded extensions and save the project.
2. Exit ArcView.
3. Re-start ArcView with a new project.
4. Select Import from the Project menu.
5. Select the old project
The imported project may have the default number format back. Run the Measure tool and see if it displays the segment length and the total length.
Warning:
If your project runs a script or extension that changes the number format, the Measure tool will again fail to display the total length. Forcing a change to the default number format may produce some unexpected results with that script or extension.
Article ID:000001918
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
