English
How To: Maximize your system's resources for ArcView 3.x
Summary
The following are tips for running ArcView more effectively on Windows machines.
Procedure
Ensure your system's virtual memory setting is adequate.
Instructions provided describe how to adjust the system's virtual memory settings. For the maximum benefit, set this value to the maximum available on the Windows operating system. For Windows 2000 and XP, the maximum available is 4096MB (4GB).
Windows 2003 Server, Windows 2008 Server, Windows Vista and Windows 7 can be set higher values than 4GB. See the link in the Related Information section below.
The drive selected for the virtual memory should have enough free space to store the page file, as defined by the initial and maximum settings. If the amount of free space on the drive is less than the virtual memory settings, the page file size uses all the available drive space. In that case, clear some space on the drive or set the virtual memory to another drive.
Select an operating system below.
Windows 7, Windows Server 2008 and Windows Vista:
  1. Click Start > Control Panel > System.
  2. Under Tasks, click Advanced system settings.
  3. In the System Properties dialog, click the Advanced tab.
  4. Click Settings under Performance.
  5. Click the Advanced tab, and click Change under Virtual Memory.
  6. Select the drive to use to store the paging file.
  7. Select Custom size and set Initial size (MB) and Maximum size (MB). For the initial size, Microsoft recommends using the recommended value in the Total paging file size for all drives box.
  8. Click Set, and click OK twice.
  9. Click Restart Now.
Windows XP and Windows Server 2003:
  1. Click Start > Settings > Control Panel.
  2. Double-click the System icon.
  5. In the Performance Options dialog, click the Advanced tab, and under Virtual memory, click Change.
  6. In the Virtual Memory dialog box, select a drive to store the paging file.
  7. Set Initial size (MB) and Maximum size. For the initial size, Microsoft recommends using the recommended value in the Total paging file size for all drives box.
To have Windows select the best paging file size, click System managed size in the Virtual Memory dialog box.
Windows 2000:
  3. In the System Properties dialog box, click the Advanced tab and click Performance Options.
  4. In the Performance Options dialog, under Virtual memory, click Change.
  5. In the Virtual memory dialog box, select a drive.
  6. Under Paging file size for selected drive, type new values for initial and maximum sizes for the disk.
  7. Click Set, click OK twice.
  8. In the Performance Options dialog, click OK.
  9. Click OK in the System Properties dialog, and click Yes in the System Settings Change dialog to restart the computer.
When the Virtual Memory dialog box is first displayed, it shows the initial and maximum page file sizes stored on each disk.
The amount of virtual memory needed depends on the size of data you are using. Although projects are often only a few megabytes, the total size of all the data accessed by a single project can be quite large. Try increasing the Virtual Memory setting to 200 MB. Extremely large projects will require a larger setting.
If you configure Windows 98/95 to let Windows manage the virtual memory, your system will always have enough virtual memory as long as there is enough free space on the C:\ drive.
Make sure your system's disk drives have ample free space.
  1. Open Windows Explorer.
  2. Right-click a drive and select Properties from the popup menu.
  3. Click the General tab to display the current drive status.
The amount of free space is important if the drive stores Virtual Memory, or if the drive stores the HOME and/or TEMP directories.
Several ESRI software packages use environment variables to define directories used for internal functions and processes. For example, ArcView uses the HOME variable, as the default working directory, to write temporary files during editing operations. If the HOME variable is not set, the TEMP directory is used. The following instructions describe how to get a list of environment variables and their values on a specific computer.
  1. Open a Command Prompt window. Type Set at the DOS prompt and press the Enter key. A list of environment variables and their defined directory paths is displayed.
  2. If a disk is low on free space, use Windows Explorer to delete files you no longer need or move files to another drive.
Extremely large TEMP and/or HOME directories (100 MB or more) can cause problems when editing data files such as themes or tables. Large HOME or TEMP directories and/or inadequate disk space can cause errors during the editing process, or can cause your data to become corrupt.
