English
Error: Fatal Application Error trying to run ArcPad
Solution or Workaround
Product: ArcPad 5.0
Platform: Windows CE
Question:
I have installed ArcPad on my Windows CE computer, however when I try to run
ArcPad, I get the following:
Application ArcPad.exe has performed an illegal operation and will be
shut down. If the problem persists, contact the program vendor.
Program: ArcPad.exe
Exception: 0xc00000005
Address: 0006c954
The software, fonts, and sample data seem to have installed correctly.
Cause:
The Windows CE computer has an older, unsupported version of Windows CE
installed.
Answer:
ArcPad 5.0 requires Windows CE 2.11. The error occurs if the Windows CE
computer is using an older version of Windows CE, for example Windows CE
2.00.
Notes:
To upgrade the version of Windows CE you need to purchase a ROM upgrade for the
Windows CE computer.
Related Documents:
84.1941 - Supported version of
Windows CE
84.1944 - Upgrading Windows CE
