English
Problem: GPS data functions don't work correctly
Solution or Workaround
Though most functions work in ArcPad running on a Fujitsu stylistic 1200, the GPS data collection functions, (such as surveying a point, line or a polygon) don't work. The GPS tool bar is not available either.
Cause
There is no projection defined, hence, the GPS button is disabled.
Solution
Define a projection.
Related Information
