English
Error: Starting ArcSDE: ORA-24314: service handle not initialized
Solution or Workaround
Problem:
When attempting to start a newly-installed ArcSDE instance on an Windows NT host which has multiple Oracle Instances, the following error may occur and be logged in sde.errlog:
ArcSDE 8.0.1 for Oracle8i Build ...
init_DB DB_instance_open_as_dba: -51
DBMS error code: 24314
Cause:
It is very likely that the value of ORACLE_SID hasn't been set properly, i.e. the ORACLE_SID in the registry isn't the one that corresponds to the new ArcSDE instance. You must set ORACLE_SID if you do not use the default ORACLE_SID (and it is a good idea to set it anyway.)
Fix:
Check for the correct setting for ORACLE_SID in these places:
1. %SDEHOME%\etc\dbinit.sde.
2. The system environment variables in the Environment tab in the System control panel.
3. In the registry under HKLM -> SOFTWARE -> ESRI -> ArcInfo -> ArdSDE -> ArcSDE for Oracle -> (instance name) -> ORACLE_SID.
4. The Oracle Home selector (provided by Oracle.)
