English
Error: FLEXlm error: -1,73. System Error: 24 "Too many open files"
Error Message
Error:
Error with socket for ethernet hostid: Too many open files
Checkout of gsrvr nnnnn, user=xxxx, client node=xxxxxxxxxx
FLEXlm Error: Cannot find license file The license files (or server network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contact your software provider for a license file.
Feature: SdeClient
Filename: /path1/sysgen/license.dat
License path: /path1/sysgen/license.dat
For further information, refer to the FLEXlm End User Manual, available at "www.globetrotter.com"...
Cause
This is a known issue with FlexLM. Each connection consumes a file handle when the LM_LICENSE_FILE value is set to the name of the license keycode file. FlexLM doesn't close license files in a timely manner.
Solution or Workaround
Instead of setting LM_LICENSE_PATH (or ESRI_LICENSE_FILE) to a pathname, use the form <port>@<host>. For example, set it to "27005@myhost" rather than "/licmgr/lickey.txt"
For help with setting a system environment variable, see:  How To: Edit an environment variable.
