English
How To: Terminating an SDE connection
Procedure
Important step to follow before terminating an SDE connection.
Solution:
Before terminating an SDE connection, it is important to make sure any map layers referencing the connection are also removed and set equal to Nothing:
Code:
Set my_SDE_Layer = Map1.Layers(layer_id)
Map1.Layers.Remove layer_id
Set my_SDE_Layer = Nothing
dc.Disconnect
The DataConnection.Connected property may return False even though the DataConnection has not successfully disconnected.
