English
How To: Create the SDE metadata for successful SDE for Informix installation
Procedure
Summary
An essential step to successfully install SDE for Informix.
Procedure
During the installation of SDE for Informix, you are instructed to run these SQL scripts:
   cr_layers
disable_colSP
enable col_SP
To do so, you must be connected to the 'sde' database as the 'sde' user. The reason is these scripts create metadata tables and routines that must reside in the 'sde' database and must be owned by 'sde'.
