English
How To: Change the color of ArcExplorer Legend Label Text
Procedure
As it is currently set up, it is not possible to change the color of the text labels for ArcExplorer's mo2legend.ocx. However, a slight modification will cause the text to be the same as the specified ForeColor.
Solution:
Edit the following line in the LoadLegend sub for the MO2Legend.ctl file:
Code:
'Display the Label
.AutoRedraw = True
.ForeColor = UserControl.ForeColor '<- was f_TextColor
After recompiling the text color can be changed by setting the ForeColor property.
