ERROR
WARNING: Parameter "OBJECTLOCKS" not found in defaults file!
Solution or Workaround
A problem can occur when installing ArcSDE 8.0.2 on a UNIX system. When starting the ArcSDE Server, the following warning message may be displayed or logged in sde.errlog:
WARNING: Setting OBJECTLOCKS to "10000"
This warning is caused by a typographical error in the file $SDEHOME/giomgr.defs.
This problem can be fixed by editing the file $SDEHOME/giomgr.defs, changing the parameter named OBJECTSLOCKS to OBJECTLOCKS.
Article ID:000001833
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
