English
Error: Hyphens in address string may cause Automation error
Solution or Workaround
The following address string will produce an automation error when you attempt to use StandardizeAddress or MatchAddress.
'2935 L ST #1 - REAR-'
Cause
Not known at this time.
Solution
Removing the lone hyphen (the one surrounded by space characters) seems to resolve the problem. Most often an address should not have a lone hyphen.
