English
Error: Error ORA-01455: converting column overflows integer datatype
Solution or Workaround
This error can occur during any ArcSDE operation that uses a spatial query, such as zooming or panning a display:
   "Error ORA-01455: converting column overflows integer datatype"
Cause
Accessing ArcSDE layers might generate an Oracle error (ORA-01455) if the spatial index is corrupted.
Answer
ArcSDE is no longer supported on Oracle 8.0.5.x for this reason. Please see the related document for more information.
