Solution or Workaround
When trying to run the gdbs command, this error appears license manager log file:
license server exiting
...read error...
giomgr has died
No related messages appear in the giomgr.log nor sde.errlog file.
Cause:
Incorrect PATH environment variable:
Solution:
1. Make sure the PATH environment variable:
a) Has the correct path to ORACLE_HOME/bin
b) ARCHOME/bin and ARCHOME/lib must follow SDEHOME/bin and SDEHOME/lib
2. Reboot your system
