Solution or Workaround
Summary
FindGeodataSet returns nothing when it encounters an invalid .prj file.
Solution
If a shapefile has a .prj file that is not parseable by MapObjects, the FindGeoDataset method will return nothing. No other errors occur, and the only way to trap an invalid .prj is to use the FindCoordinateSystem method and see if it returns nothing.
