English
How To: Publish Map Librarian data using ArcSDE for Coverages
Summary
This document shows how to publish Map Librarian data using ArcSDE for Coverages so they can be accessed from ArcInfo Defined Layers, ArcInfo Desktop, Arcview, and ArcIMS.
Procedure
  1. Start the service using the ArcSDE for Coverages command.
    Code:
    SDEMON -o start
  2. Use the ArcSDE for Coverages command LAYERUTIL to register the Librarian layer. The Librarian layer is specified using the -L option* as follows.
    Code:
    LAYERUTIL -o register -l <ArcSDE_layer_name> -L LIBRARY.LAYER
    For more information on accessing and connecting to 'SDE for Coverages' data from ArcCatalog, refer to the chapter 'Building the Catalog' in Using ArcCatalog.
