English
How To: Publish ArcStorm data using ArcSDE for Coverages
Summary
Instructions provided are to publishing ArcStorm data using ArcSDE for Coverages so they can then be accessed from ArcInfo Defined Layers, ArcInfo Desktop, Arcview and ArcIMS.
Procedure
  1. Start the service using the ArcSDE for Coverages command.
    Code:
    SDEMON -o start
  2. Register the Arcstorm layer, the -L option is used as follows.
    Code:
    LAYERUTIL -o register -l <ArcSDE_layer_name> -L DATABASE.LIBRARY.LAYER
    Once the data has been registered successfully into ArcSDE for Coverages, the ArcSDE layers can then be accessed from ArcInfo Defined Layers, ArcInfo Desktop, Arcview and ArcIMS. However, the ArcSDE layers are READ only.
