English
How To: Convert Map Librarian/ArcStorm data to a GeoDatabase.
Summary
How to convert a Map Librarian/ArcStorm data to a GeoDatabase.
Procedure
  1. Serve your Map Library
    <a href='http://support.esri.com/en/knowledgebase/techarticles/detail/12632' target='_blank'>How To: Publish Map Librarian data using ArcSDE for Coverages</a>/ArcStorm
    <a href='http://support.esri.com/en/knowledgebase/techarticles/detail/12633' target='_blank'>How To: Publish ArcStorm data using ArcSDE for Coverages</a> data using ArcSDE for Coverages.
  2. In ArcCatalog, right click on the data you served.
  3. Click on "Export" > "Geodatabase to Geodatabase"
  4. Choose existing Geodatabase in dialogue.
  5. Click on Finish.
