English
Problem: DISSOLVE command does not function in DAK
Solution or Workaround
Why does the DISSOLVE command function not work for the DAK?
Answer:
The files associated with the DISSOLVE command were left out during the building of the DAK.
In order to use the DISSOLVE function within the DAK 3.5.2, you need the
following executable:
1. DISNEWPA.EXE
2. DISFORMA.EXE
3. DISOLV.EXE
4. DISTABLE.EXE
You can retrieve these files from the PC ARC/INFO OVERLAY zip file, which is
located in the directory RCEXE\PROGRAMS. You must place these files in the DAK\PROGRAMS directory.
