English
Error: 2nd parameter must be POLY, LINE or POINT
Solution or Workaround
Error Message
The BUILD command returns this message:
Usage: BUILD [cover] [POLY / LINE / POINT]
Cause
In version 3.5.2 the BUILD command does not have the POLY default parameter as earlier versions did.
Solution
You must specify the type of BUILD to be performed (POLY / LINE / POINT).
