English
How To: Configure the Summagraphics Summagrid III, 16-button digitizer
Procedure
Summary
Steps to configure a Sumagraphics Summagrid III, 16-button digitizer.
Procedure
1. Set your dip-switches to emulate the Calcomp 9100 format:
   9600
8 data bits
No parity
1 stop bit
Point mode
ASCII format
ACSII inches
No decimal
CR only
1000 lpi
The 'ON or 1' and 'OFF or O' dip-switch settings on the Summagrid IV can be confusing. The dip-switch is 'ON or 1' when the switch is towards the numbers. The dip-switch is 'OFF or O' when the switch is towards the OPEN label.
Switch A:
1 2 3 4 5 6 7 8
on off off X off off on on
- 1 9600 baud
- 2 9600 baud
- 3 9600 baud
- 4 don't care
- 5 no parity
- 6 1 stop bit
- 7 8 data bits
- 8 ASCII format
Switch B:
1 2 3 4 5 6 7 8
off off off off off on on off
- 1 ASCII inches
- 2 no decimal
- 3 CR only
- 4 inches
- 5 1000 lpi/ 40 lpmm
- 6 1000 lpi/ 40 lmpp
- 7 calcomp 9100 format emulation
- 8 calcomp 9100 format emulation
Switch C:
1 2 3 4 5 6 7 8
on off off off off ? ? ?
- 1 point mode
- 2 point mode
- 3 echo off
- 4 transmit only when in proximity
- 5 beeper disabled
- 6 application dependent <-- 6 indicates the digitizer's size
- 7 application dependent <-- 7 indicates the digitizer's size
- 8 application dependent <-- 8 indicates the digitizer's size
The appropriate digitizer board size settings for Switch Bank C, dip-switches 6, 7 and 8 are:
dip-switch    6    7    8
18" x 24" on on off
36" x 48" on off off
24" x 36" off on off
44" x 60" off off off
2. Create the following digform format file with an ASCII editor (e.g. DOS Edit, NOTEPAD, WORDPAD):
'SGRID3'                    		Summagraphics Summagrid III
1 Digitizer device #
'(A3,2F5.3)' Digitizer format
F No menu bar
F Single button mode off
73.0, 1.0, 0.0 X max, x scale, x offset
85.0, 1.0, 0.0 Y max, y scale, y offset
12
'APD' 0, 'AP0' 1, 'AP1' 2, 'AP2' 3, 'AP4' 4, 'AP5' 5,
'AP6' 6, 'AP8' 7, 'AP9' 8, 'APA' 9, 'APC' 10, 'APE' 12
-1
-1
-1
-1
-1
3. Save the file as SGRID3 and place it in the C:\ARCEXE\DIGFORMsub-directory.
4. Run CON-DIG at the Arc prompt like this:
CON-DIG SGRID3 x 9600 NONE 8 1
| | | | | |_ stop bits
| | | | |___ data bits
| | | |________ parity
| | |_____________ baud rate
| |_______________ port #
|______________________ format file
5. Run DIGTEST (for DOS) or DIGTESTW (for Windows Extensions) utility to ensure the digitizer is configured correctly.
This digitizer is only supported in the POINT MODE of operation. STREAM MODE of operation is not supported.
A sample of the correct RAW DATA that can be obtained in KERMIT or the 1st test in DIGTEST or DIGTESTW is:
AP00123401567  <-- for pushing the '1' button on the puck
APC1000218213 <-- for pushing the 'A' button on the puck
Related Information
