English
How To: How to configure the HIPAD+ 9636 digitizer
Procedure
Summary
Steps to configure a Houston Instruments HIPAD+ 9236 digitizer.
Procedure
The Houston Instruments HIPAD+ 9236 digitizer is considered part of the HIPAD 9200 series digitizers. This digitizer can be configured with software drivers and a paper menu template. At this point the only procedure known on configuring the digitizer is with the paper menu template.
1. Check the following paper menu template configuration areas:
HOUSTON ASCII: 8 DATA BITS/NO PARITY
TABLES RESOLUTION: 1000 LINES PER INCH
BAUD RATE/STOP BITS: 9600/1
PRIMARY MODES: POINT MODE
INCRIMENT LIMIT: 5 COUNTS
OUTPUT RATE: 200 COORDINATES PER SECOND
2. Use a text editor to create the following digform file needs to be created:
'HIPAD-2'
'(A1,T4,F5.3,T12,F5.3)'
F
F
73.0, 1.0, 0.0
85.0, 1.0, 0.0
12
'0' 0, '1' 1, '2' 2, '3' 3, '4' 4, '5' 5,
'6' 6, '7' 7, '8' 8, '9' 9, 'A' 10, 'B' 12
-1
-1
-1
-1
3. Name this file HIPAD-2 and
saved it in the C:\ARCEXE\DIGFORM\ sub-directory.
4. Run CON-DIG at the Arc prompt like this:
CON-DIG HIPAD-2 x 9600 NONE 8 1
| | | | | |_ stop bits
| | | | |___ data bits
| | | |________ parity
| | |_____________ baud rate
| |_______________ port #
|_______________________ format file
5. Run DIGTEST, DIGTESTW, or KERMIT to make sure the digitizer is working correctly. The RAW data from the digitizer should reveal something like this:
1 019326  010361  <-- pushing the '1' button
2 003654 001807 <-- pushing the '2' button
Related Information
