English
Problem: ZOOM menu choice magnifies all symbols
Solution or Workaround
Using the Zoom option in ARCEDITW magnifies all marker symbols for labels, tics, nodes, node errors, and so forth.
Cause
The PC ARC/INFO Zoom feature is zooming into the display list only. The MAPEXTENT remains unchanged.
Solution
All PC ARC/INFO 3.5.2 graphics modules use WINDOWS display lists to store the graphics, this allows for very fast redraws. The Zoom option on the menu zooms into the display list only, so it does not regenerate the underlying graphics.
The proper way to zoom in to an area and keep the default symbol sizes is to use the MAPEXTENT command. Once the new MAPEXTENT is set, redraw the graphics.
