English
Error: ILLEGAL FONT NUMBER -972 [FNTGET]
Solution or Workaround
Summary
This error occurs when trying to load the PATTERNS or TRUETYPE marker sets in the DOS version of ARCPLOT:
The error will persists when loading a marker set that worked in previous ARCPLOT sessions.
Cause
The PATTERNS and TRUETYPE marker sets are to be used only in the Windows Extension of ARCPLOTW.
Solution
To ensure a marker set doesn't interfere when loading another set, use the MARKERSET command with the CLEAR option:
Code:
MARKERSET <marker set> CLEAR
Related Information
