English
Error: Configure the KURTA IS/ONE 12 x 12 digitizing board
Solution or Workaround
Summary
Steps to configure the KURTA IS/ONE 12 x 12 digitizing board.
Procedure
1. Set the Switch C like this:
SC 1 2 3 4 5 6 7 8
The settings for SA and SB are the same as indicated in the Technical Hardware Guide.
2. Load the digform file into a text editor and make the following changes:
'KURTAIS1'
'(A1,F5.3,T7,F5.3)'
T
F
75.0, 1.0, 0.0
85.0, 1.0, 0.0
'1' 1, '2' 2, '4' 3, '8' 9 <---modified for a 4 button puck.
-1
-1
-1 No stream mode on
-1 No stream mode off
0 Stream mode off wait time.
3. Run CON-DIG at the DAK prompt with the parameters described in the Technical Guide:
4. Run the DIGTEST utility to make sure the digitizer is working correctly.
