English
Error: Could not open C:\TEMP\ t$arc0\FORT1
Solution or Workaround
Summary
This error occurs while attempting to start a module or a standard arc command:
Cause
The system is finding the executable before the batch file that initializes and writes the FORT1 file.
Solution
Delete and/or move the misplaced executable.
Both the standard arc commands (ptool) and the modules (ARCPLOTW, ARCEDITW, etc.) should have their executables only in the programs subdirectory.
The FORT1 file is a temporary ASCII file that stores the parameters set in the batch file. The batch file writes the FORT1 file through a series of statements
such as:
   ECHO %1 >%WKSP%FORT1
The executable then reads them in. The batch file deletes the FORT1 file when the process is finished.
