English
Error: Cannot project point in TIC file
Solution or Workaround
Summary
This message occurs when running the PROJECT utility, for the StatePlane projection, on an ANNOTATION cover:
Warning: By selecting STATEPLANE as a projection,
the datum will default to NAD27 if not specified.
Cannot project point in TIC file.
Cause
Bad coverage TIC values.
Solution
Delete all bad TIC values need:
1. Start TABLES
2. Open the TIC file
3. Select Modify Record
4. Change the TIC ID
5. Click WRITE at the top of the window
6. Quit TABLES
7. Redraw your coverage and the new TIC ID's will be displayed.
This is an example of a projection parameter .SML file:
Code:
INPUT
PROJECTION STATEPLANE
UNITS FEET
ZONE 4701
DATUM NAD27 NADCON
PARAMETERS
OUTPUT
UNITS FEET
ZONE 4701
DATUM NAD83 NADCON
PARAMETERS
END
