English
How To: Configure a GTCO Accutab digitizer for stream mode
Procedure
Summary
Steps to configure a GTCO Accutab for stream mode digitizing.
Solution
A GTCO Accutab can be configured for stream mode digitizing by emulating a CAL9100.
1. From the Program menu on the top of the digitizing board select:
	A 26
2. Run CON-DIG at the DAK prompt like this:
CON-DIG CAL9100 x 9600 N 8 1
| | | | | |_ stop bits
| | | | |___ data bits
| | | |_____ parity
| | |__________ baud rate
| |____________ port #
|____________________ format file
3. Run the DIGTEST utility to make sure the digitizer is working correctly.
