English
How To: Configure the KURTA XLC digitizing board
Procedure
Summary
Steps to Configure the KURTA XLC digitizing board.
Procedure
The best way to configure the KURTA digitizing board is to emulate the GTCO DIGI-PAD 5.
1. If you installed the drivers for the KURTA board, uninstall them.
2. Get the button settings. Run KERMIT and press each of the buttons on the digitizer. Record the characters that appear on the screen. You will need these values to modify the digform file. Example:
Pressing button 16 displays @
In the digform file: '@' 0
3. Copy the GTCO5 digform file to KURTAXLC.
4. Edit the KURTAXLC digform file to accommodate the 16-button puck:
'KURTAXLC'             Digform's file name
1 Device driver #
'(A1,F5.3,1X,F5.3)' Format
F Menu bar off
F Single button mode off
73.0, 1.0, 0.0 X max, x scale, x offset
85.0, 1.0, 0.0 Y max, y scale, y offset
12 Key conversion table
'@' 0, '1' 1, '2' 2, '3' 3, '4' 4, '5' 5
'6' 6, '7' 7, '8' 8, '9' 9 ':' 10, ';' 12
-1 No initialization characters
-1 No shut down characters
-1 No stream mode on
-1 No stream mode off
0 Stream mode off wait time.
* 0 is actually set to be button 16
* A is set to be button 10
* B is set to be button 12
5. Run CON-DIG at the DAK prompt like this:
CON-DIG KURTAXLC x 9600 N 8 1
| | | | | |_ stop bits
| | | | |___ data bits
| | | |_____ parity
| | |__________ baud rate
| |____________ port #
|_____________________ format file
6. Run the DIGTEST utility to make sure the digitizer is working correctly.
Related Information
