English
How To: Configure a GTCO SUPER L II digitizer
Procedure
Summary
Steps to configure a GTCO SUPER L II digitizer.
Procedure
1. Make sure the dip switches are set like this:
Switch 1:		Switch 2:		Switch 3:
1 - off 1 - on 1 - off
2 - off 2 - on 2 - off
3 - on 3 - on 3 - off
4 - on 4 - on 4 - off
5 - off 5 - on 5 - off
6 - off 6 - off 6 - off
7 - off 7 - off 7 - off
8 - on 8 - off 8 - on
2. Run CON-DIG at the Arc prompt like this:
CON-DIG GTCO5 x 9600 N 8 1
| | | | | |_ stop bits
| | | | |___ data bits
| | | |_____ parity
| | |__________ baud rate
| |____________ port #
|__________________ format file
3. Run the DIGTEST utility to make sure the digitizer is working correctly.
