English
Problem: CLEAN hangs PC while creating PAT
Solution or Workaround
Cleaning a cover, using an international version of PC ARC/INFO, hangs the PC while it is creating PAT.
Cause
An affirmative response to the Yes/No prompt us not being recognized.
Solution
Load the ARCEXE\CPLLIB\YES.PAR into a text editor and change the fist letter representing an affirmative response in your language:
For Spanish, use the letter "S".
For German, use the letter "J".
For French, use the letter "O".
The default is the letter "Y", for yes in English.
