English
Problem: DAK doesn't install completely and top portion of monitor appears blank
Solution or Workaround
Summary
The DAK installation bombs at 99%. After rebooting the PC, starting the DAK causes the top portion of the monitor to appear blank.
Cause
Most likely the video card has been set for more than 256 colors.
Solution
Check the video driver settings and make sure you are using no more than 256
colors. Run the DAK again.
The DAK supports standard VGA and SVGA modes of video display operation. The following are examples of supported resolutions/color settings:
   640x480x16
640x480x256
800x600x256
These are examples of non-supported video driver resolutions/color settings:
   640x480x32000
800x600x32000
800x600x16Million
