English
How To: Configure NUMONICS BIDMAT XNT digitizer with 16-button puck
Procedure
Summary
Steps to configure the NUMONICS BIDMAT XNT digitizer with 16-button puck.
Procedure
Since this digitizer is not supported, the best way to configure it is using the CALCOMP 9100 format:
1. Configure the dip-switches on the digitizer banks A and B as follows:
                        1 1 1 1 1 1 1 1 1
BANK 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8
A 0 1 0 0 0 1 1 1 1 1 0 0 0 1 1 0 0 1
B 0 0 1 1 X X 0 X 1 X X X X 1 X X 0 0
where 0 = OFF, 1 = ON and X = Does Not Matter
According to the NUMONICS BIDMAT XNT documentation, this will emulate a CALCOMP 9100 format #1 digitizer. The dip-switches on this digitizer are actually a menu bar with lights embedded in the digitizer. You need to select a particular bank with the digitizer puck and move the cross-hairs over each light to see if it is ON or OFF.
2. Save the above bank setting as the digitizer default.
3. Using a text editor, load the C:\ARCEXE\DIGFORM\CAL9100 digitizer format file. Edit it so it looks like this:
'BIDMAT'
'(A2,2F5.3)'
F
F
73.0, 1.0, 0.0
85.0, 1.0, 0.0
12
'1D' 1, '2D' 2, '4D' 3, '5D' 4, '6D' 5, '8D' 6,
'9D' 7, 'AD' 8, 'CD' 9, '0D' 0, '3D' 10, '7D' 12
-1
-1
-1
-1
-1
4. Save it as C:\ARCEXE\DIGFORM\BIDMAT.
5. Run CON-DIG at the Arc prompt like this:
CON-DIG BIDMAT x 9600 NONE 8 1
| | | | | |_ stop bits
| | | | |___ data bits
| | | |________ parity
| | |_____________ baud rate
| |_______________ port #
|______________________ format file
6. Run the PC ARC/INFO utility DIG-TEST to ensure the digitizer is communicating correctly.
On newer PCs, the serial port may not initialize upon starting PC ARC/INFO, in such case you need to edit C:\ARCEXE\CMD\ARC.BAT. Enable lines 20 & 21 by removing the REM text:
Original lines:
REM SET COMSPEC=%COMSPEC%
REM %ARC%\CMD\KERMIT -F %ARC%\CPLLIB\KERMIT.PAR > NULL
Enabled lines:
Related Information
