English
How To: Configure NUMONICS Accugrid 6090 digitizer with 4-button puck
Procedure
Summary
Steps to configure a NUMONICS ACCUGRID 6090 digitizer with a 4-button puck.
Procedure
The NUMONICS ACCUGRID 6090 digitizer needs to be configured to emulate a CALCOMP 9xxx type of digitizer.
1. Make a copy of the CAL9000 digform and call it NUMO6090.
2. Modify the NUMO6090 digform:
'NUMO6090'
'(A2,2F5.3)'
T
F
73.0, 1.0, 0.0
85.0, 1.0, 0.0
'0D' 1, '1D' 2, '2D' 3, '3D' 9
-1
-1
-1
-1
3. Run CON-DIG at the Arc prompt like this:
CON-DIG NUMO6090 x 9600 N 8 1
| | | | | |_ stop bits
| | | | |___ data bits
| | | |________ parity
| | |_____________ baud rate
| |_______________ port #
|________________________ format file
4. Run the DIGTEST diagnostic program to make sure the digitizer works correctly.
For Point Mode, use the following menu settings:
Output format: ASCII Fmt 3
Interface:
Baud: 9600
Data: 8
Parity: none
Stop: 1
Modes: Point
Increment: 0
Stream Rate: max
Resolution: 1000
ASCII Options: CR & LF are dependent on host
Transmit out of Prox: Disable
