English
Error: FATAL ERROR LINK. 1290: UNKNOWN COMMAND SWITCH - HEON
Solution or Workaround
Summary
This error occurs when typing COMMAND or COMMANDS at the Arc prompt:
Cause
The batch file L.BAT or the executable file L.EXE are conflicting with PC ARC/INFO's batch routines within the COMMAND.BAT and COMMANDS.BAT files.
Solution
Locate the offending L.BAT or L.EXE files and rename them to something else.
The L.BAT file and L.EXE files are used in Fortran programming.
A similar problem is known to have occurred with the existence of W.BAT and W.EXE files.
