English
How To: Configure the Summasketch III with 4-button puck
Procedure
Summary
Steps to configure a Summasketch III with a 4-button puck.
Procedure
Initialize the digitizer with the following SEND command. Since it has a 4-button puck, it has already defaulted to MM format.
SEND /port /m /o /Czaczr
Run CON-DIG at the Arc prompt like this:
CON-DIG SUMSKET x 9600 NONE 8 1
| | | | | |_ stop bits
| | | | |___ data bits
| | | |________ parity
| | |_____________ baud rate
| |_______________ port #
|_______________________ format file
If the output is in four digits instead of five, and the highest x,y values represent half the the size of the board, try the SEND command with the j switch:.
SEND /port /j /m /o /Czaczr
See the document below for notes on known switches and creating batch files.
Related Information
