English
Problem: Projecting Wessex data locks up computer
Solution or Workaround
Attempting to project data extracted from the WESSEX First Street CDs, from geographic decimal degrees to UTM (or something else), locks up the computer.
Cause
Tics with extremely large or small values. For example: tics
x,y values of -.9999000E+36 or .9999000E+36
Solution
Delete all tics with values radically outside the range of the BND file. For example:
Code:
Tables
SELECT cover.tic
RESELECT xtic > 1000 or xtic < -1000
PURGE
QUIT
BUILD cover line
Project the data again.
