English
Error: Bad command or file name
Solution or Workaround
Summary
Import coverages from Trimble GPS yields this message:
The resulting coverages do not have any attributes.
Cause
Trimble export creates an SML that calls dBase. dBase populates the empty fields from ASCII data. If the system doesn't have dBase installed, the resulting coverages will not have any attributes.
Solution
1. Export from Trimble using the ARC/INFO - INFO option
2. Rename the <cover>.inf to inf.sml
3. Remove the first line (ARC statement) of the inf.sml file.
4. Edit the <cover>.sml to replace the line:
   INFO <cover>.inf
With:
   TABLES INF.SML
5. Start ARC and type &RUN <covername>.sml
