English
Error: Unable to create directory, Path not found
Solution or Workaround
Summary
This error occurs when starting PC ARC/INFO:
Path not found
Bad command or file name
Cause
The C:\TEMP directory is not present.
Solution
Create the C:\TEMP directory.
