English
Error: Unarchiving ARC... Bad command or file name
Solution or Workaround
Summary
When starting ARC, the following messages occur:
Unarchiving ARC
Unarchiving STARTLOG
Unarchiving ENDLOG
Unarchiving CHKPAR
Directory already exists
Cause
The variable ARC was set to an incorrect path.
Solution
Check the AUTOEXEC.BAT and make sure ARC is set correctly. For example, if PC ARC/INFO was installed on the default directory:
SET ARC=C:\ARCEXE
